1 1iwilly Android Enthusiast Sep 11, 2011 #1 on the senserom how do i change the background color on the upper bar the one that shows the signal,batt,and so on. thanks
mystifire2 Well-Known Member Sep 12, 2011 #2 1iwilly said: on the senserom how do i change the background color on the upper bar the one that shows the signal,batt,and so on. thanks Click to expand... probably the easiest way is to apply a theme
