Hello CSEV, welcome to Android Forums!
What phone do you have? Some of the stock text apps have that option, but not all.
If you really want a customized text app, check out one called (I think) handsent. I believe there is a free and paid app in the market, and it is quite customizable from what I remember.
If your stock app does support changing the background color, then it likely is with the menu button and then something like settings or customize.
Hope that helps, and welcome to Android Forums,
9to5
