Root Backing up and restoring 2.2 stock rom
rolyk
I'd like to try a custom rom on my rooted Desire. If I want to revert back to the stock rom is this possible? I realise that it's easy to swap from one custom rom to another but not sure about restoring the stock rom.
You can use an ruu if one is available.
What's your software build / version in settings, about phone?
Thanks for reply.
Software Build 2.25.771.1 CL254759
Baseband 32.48.00.32U_5.11.05.14
The phone is locked to 3 Mobile
Thanks guys. But maybe I should have been more specific. If I've done a nandroid backup can't I restore the stock rom from that? Or can a stock rom only be installed / restored by using the RRU?
I do a regular Titanium backup so it would be easy enough to restore apps etc from that.
Roly
