Backing up phone contacts to SD card / GMail
Ok to save contacts onto the SD card.
Open People
press Menu
Import/export
Export to SD card
Phone
All your phone contacts get export to the SD card as a Vcard.
If you want to upload these to google you then ...
Open People
press Menu
Import/export
Import from SD card...
You get a choice of which account to create under. You choose your gmail account and it will put them all into google.
You will then get duplicates of your contacts. You can choose only to display only the gmail contacts, or you can link the duplicated contacts together.
