Root Backup for ZTE avid
dadcup
Android Expert
Hello everyone well i took the time and i made a backup of stock rom that way if you guys want to go back to stock just hit restore and that it cool right ok
i made and stock root and stock unroot to make things easy
How to use the backup :
1 download the backup in your pc or your phone
2 unzip and put the backup in clockworkmod folder in
/sdcard/clockworkmod/backup folder that way the cwm can see the backup when you are in recovery
3 if you going to use the backup go in to recovery by turn your phone off and hold power key and volume key up that way you boot in recovery when you are there go in to backup and restore option and select restore then select the backup and your phone will be back to stock :D
ok hope this help thanks to everyone in this forum :)
root version : Stockbackup-root - Download - 4shared
unroot version : stockbackup-unroot - Download - 4shared
this stock backup are full stock no change nothing done :)
Did you make sure you didn't have any account info of yours on there before you made backups?
do you need clockworkmod to run this recovery. if so which clockwork mod do you use?
and if you can leave a link thad be a great help.
This is a backup to go back to stock and yes you need clockworkmod to run this and don't matter what version I think the best one is the last one totlth made for us
I recently rooted my zte avid to use the freedom apk and also uninstalled the easy wifi app, now I can't get into any google services even after unrooting and a factory reset so my question is can I get clockwork mod from 4shared and what one do I get so I can fix my phone?
