Backup issues
paganguardian
So i've got the Jellyverse rom and I caught that they have an agat recovery for the gc01 kernel. When I go to backup my rom, it starts doing what it's suppose to but around when it's backing up the apps, the phone just reboots itself, going to my main screen like a normal boot up would. When I go back to the recovery menu and try to restore what I just backed up, it says md5 mismatch. What's going on?
What version of the kernel did you get? Anything higher than 0.1.0 is having issue. Also, do not do a data wipe in the recovery.
As long as my phone can reboot properly, I guess I can live without a recent backup. I have it to where it will at least restore the fresh copy of the rom. I'll just wait and see what gets resolved. You know anything about the battery usage on jellyverse? Like if it's known to drain fast?
ok that is your problem. 030 they tried do update it with new governors etc and they are having problems, and are having a timeout reboot issue in recovery. Version 0.1.0 is basically stock plus recovery. I am sticking to 0.1.0 as my daily driver until they have the bugs worked out.
