Is there a app out there will back up all my phone contacts to the sd card?
A ajaynsx Lurker Jul 27, 2010 3 0 Aug 12, 2010 #1 Aug 12, 2010 Add bookmark #1 Is there a app out there will back up all my phone contacts to the sd card?
T treborcj Android Enthusiast Dec 11, 2009 646 33 Aug 12, 2010 #2 Aug 12, 2010 Add bookmark #2 Try using that search button. I know I answered this question before. You don't need an app. Go to people > menu > import/export > export to sd Upvote 0
DonB ♡ Truth, Justice and the American Way !! ♡ ™ Moderator Nov 30, 2009 20,582 10,597 18th Hole Of the Golf Course Aug 12, 2010 #3 Aug 12, 2010 Add bookmark #3 Took the words out of my mouth, best way to do it, there are programs but they are not needed treborcj said: Try using that search button. I know I answered this question before. You don't need an app. Go to people > menu > import/export > export to sd Click to expand... Upvote 0
A ajaynsx Lurker Thread starter Jul 27, 2010 3 0 Aug 13, 2010 #4 Aug 13, 2010 Add bookmark #4 I did what you guys told me to do but it is exporting only 1 contact not all the contacts.. Is there a why for me to export all contacts? Upvote 0
S sig sauer Member Jun 28, 2010 61 5 Aug 14, 2010 #5 Aug 14, 2010 Add bookmark #5 Damn, had my Hero almost 3 mos, with no issues aside from the occasional lag on outgoing calls. Best phone I've ever had. Upvote 0
T treborcj Android Enthusiast Dec 11, 2009 646 33 Aug 15, 2010 #6 Aug 15, 2010 Add bookmark #6 ajaynsx said: I did what you guys told me to do but it is exporting only 1 contact not all the contacts.. Is there a why for me to export all contacts? Click to expand... Do you have more than one phone type? ie: google, phone If so, then you have to do it for each type. Upvote 0
