Danielson2047
Is there any difference between the back up that ROM manager makes and Nandroid? Reboots to what looks like the same screen. Also, will either of these restore my home screen icon configs? Thanx.
Yeah, i have Clockwork recovery right now, and i thought it seemed kinda glitchy, freezing and things like that. But i found mybackup pro, and that does home screen icons, so problem solved!!! Thanks again guys!!!!
so here is a question then on this topic, my Clockwordmod directory shows I have 3.15G (10) of backup files and nandroid has 577.99 mb (2).. IF in fact they are the same backup method, what is that nandroid directory even holding?
"if you're sure you're never going back to SPRecovery" - frankly, as unstable as ClockworkMod seems to be for many, I think going back to SPRecovery is always a potential, so I will keep it around.
