Root Backup Question..
Wally World
Android Expert
Ok, newb in rooting relm and have a question.
Stock Rom, rooted, installed Titanium BU, Koush's Bootstrap. I froze a few of the bloatware apps and made a nandroid backup. Is this the right way to do it? Or should have I made the backup without anything frozen?
probably good to have a clean backup but it is easy to defrost apps in TIBU so no worries.
+1
So when/if the OTA updates come out, I can install the backup then I probably need to unfreeze everything in order of it to work?
In theory yes.
App/data backup should also be part of your backup scheme. Titanium Backup (free) is a good start, but it will only save the latest backup. The Pro version will save many more. Your first backup (every backup if using free version) should be all apps - all data.
If I were to do it over, I'd root, install bootstrap recovery, rom manager, and Titanium before making my first recovery backup.
EDIT: just reread your post and realize you have Titanium Pro. Still others read and learn from these posts so will leave my rant. :D
