B bha19 Newbie Nov 28, 2013 #1 Here is my my question: I did a backup using clockwork mod and then installed CM10, but now I need to know how to put all my old apps back on the touchpad by a restore.
El Presidente Beware The Milky Pirate! VIP Member Nov 28, 2013 #2 The paid version of titanium backup can restore apps from nandroid backups. You're best to use TB before you flash the new ROM though.
Rukbat Extreme Android User Nov 28, 2013 #3 There are also other programs that can do partial restores from nandroid backups.
D Deleted User Guest Nov 29, 2013 #4 bha19 said: Here is my my question: I did a backup using clockwork mod and then installed CM10, but now I need to know how to put all my old apps back on the touchpad by a restore. Click to expand... Look in CWM Advanced restore. Restore only /data from the backup you made. I have done this several times and it works quite well.
