TivoTron
Like many, I've had a real problem with a loose headphone jack on my Droid. As the jack gets moved (bumped in my pocket, for example) it causes the music player to turn on/off, which is super annoying. To describe it better, if I were to hold onto the headphone end piece where it connects and move it around, I can trigger the music on and off...it must be moving the connector inside somehow.
Had the Droid replaced once. New Droid - same issue. Crap!
New idea --- Is there any way to entirely disable the headphone's ability to control to Droid? My thought is that if I can turn that off altogether, it will no longer be a concern that it's loose.
Help please!!!
Thanks.
Help please!!!
Thanks.
