Root Baked snack 1.8 check
mti22
Member
Ok so I think I did everything right and was able to get all my apps and layout back with contacts and what not.. Have to setup my emails but other then thhat seems to be good.
Andriod Verzion
2.2
Baseband verzion
2.15.00.07.28
Kernel verison
2.6.32.15 HeroMod hero@hero-over#2 (is this kernel 6?)
Build #
3.29.651.5 CL252548
Software #
Baked Snack
Broswer version
Webkit 3.1
PRI Version
1.40_003
PRL version
60671
Let me know if it looks good .. I would have taken a screenshot but have to set up my email.
That's #6 Kernel,I know it reads #2 but is actually 6.Some are claiming to get better overall performance if you reflash the #6 Kernel.I have never run a Backed Kernel so I can't vouch for this,but there plenty of people in here that will.
By the way update ur PRI is as easy as flashing a Kernel.
AWESOME! Now I know how to do everything, its time to get into some different lock screens and everything else...
And what is the PRI, and would you have a link for that?
