Has anyone been successful with doing it this way? Seems pretty easy.
It was very easy. No problems at all.
did you have to wipe everything or no? I am looking to keep my wallpaper nd launcher will that stay the same? and what kernal does this start you with?
Is Baked Snack better than Fresh? Can you provide a comparison?
I have not installed Fresh yet. I do like BS. I'm going to give Fresh a go in a few days...
There are several threads on the forum that discus the two ROMs. It really seems to be a subjective opinion. From what I've read, you won't go wrong with either.
So far it's the same to me. The interface looks a bit different but that's all really.
Honestly, my phone seemed faster and snappier when I was able to use Launcher Pro instead of sense on an older Fresh.
Is there someway to get this back? Is there a kernel to make Baked Snacks have higher FPS?
I'm also trying to download FPS2D and it's stuck on "starting download."
Not liking this at all so far... I must be missing something.
ROM Manager did wipe the phone. Wallpaper and launcher will change. BS 1.8 comes with Baked Kernel #6. I didn't flash another kernel.
Okk so all I need to do is open up ROM Manager and download baked snack 1.8 then go to install ROM from SD card and thats that?
I have everything backed up with titanium backup pro and once all that is done just click the apps I want back??
After you tap "Install ROM from SD Card" you will have to scroll to the actual ROM zip and select it. I think it's called BakedSnack1.8.evo.zip.
I can't remember the steps after that but just follow the instructions. I would recommend doing the cache and data wipes. It's a little more trouble reinstalling your apps but it's worth it to minimize other issues.
ok cool and the titanium backup that i did is what i needed to do, and won't lost my contacts pictures any of that right?
I'm not going to guarantee that your backup will restore everything because I don't know which backup you did in Titanium. If you did the "Backup all user apps + system data" batch then you should be ok when you restore. You will have to redownload the Titanium Backup app from the market before you can restore. Once you download the app, make sure to update the BusyBox again and then do your restore. I've flashed several ROMs and about the only thing that doesn't come back when I restore is my SMS messages but I don't care about those anyway.
Your contact pictures should sync back correctly once you sign back into your Google account.
Is there any other backups cuz im not seeing "backup all user apps + system data" just have to click one by one and click back up.
How would i know if i have the latest version of Bake Snack?
anyone run Kingxklick kernal #11 on B.S. 1.7? I am not feeling like flashing to a new rom (e.g. 1.8) but thought a new kernel might help battery life, any experiences appreciated
