Which one do you think is the best? I an running #5. My battery seems to drain somewhat quickly. Anyone using a different,one and getting good speed and battery life??
U might wanna try netarchy's or king's kernels... they provide good performance and good battery life. IMO netarchys is a overall a more stable kernel, everything runs smooth, but that's just my preference
1.7 has known problems. Im waiting on that.
I used 1.7 for about 4 days and it ran fantastic. No issues at all. Usually the issues you hear about are from people with bad flashes or apps causing other problems.1.7 has known problems. Im waiting on that.
I am now on Virus's Rom and it is great as well. I am using Baked Kernal #6 and it gives great battery life and runs really smooth. Not the fastest in benchmariking (I am not oc'ing), but seems to run smoother then the faster kernels.
I'm running Net's 4.1.9.1-CFS paired with EViO2 v1.2 .
