12 hours ago, if asked how my D1 was doing, I would have said "perfect, never been better!"
It's rooted, CM6 w/ stock kernel, SetCPU @ 800 screen-on/250 asleep, ADW Launcher, no themes, few widgets... suits me fine, very stable, good batt life. I manually turn my radios on and off as needed with the (wonderful!) Power Control widget in CM6. Also using Tasker to automate GPS radio upon opening a nav/map app.
and WiFi was working fine yesterday, turned it on this morning... nothing. I used it just yesterday afternoon, when I saw an update notification for 4 apps... turned on WiFi, went to Market and did "download all", came back to the phone later and turned WiFi off. updated Apps were:
Gmail 2.3
ROM Manager premium
LEDs Hack
Gentle Alarm
I've searched here, and tried all suggestions found:
first, airplane mode on/back off, several times
then, reboots, incl. a battery out one for 5 min while power-cycling both APs
checked and re-checked all the Settings I can find on the phone
fixed permissions using Rom Mgr
Used CacheMate to clear cache (I know, I know... grasping at straws
Both my laptops can still see both of the APs in my house, and I have no neighbors to "step on my signal".
The phone WiFi radio works... I turned on Wireless Tether, and this laptop connected to it and browsed over 3G just fine.
In the list of networks I've connected to, on the WiFi Settings screen, both my APs are listed as "Not in range". In Advanced, I set Sleep Policy to "never" (and have considered putting in a Static IP, just to experiment?).
Fortunately, just a few days ago I did total backup... Titanium, nandroid, then copied the entire SD card to the "DROID stuff" folder on my laptop. If I have to, I guess I could start from scratch, but dammit!... I sure don't want to have to. So, finally, my question:
Any suggestions?
Gmail 2.3
ROM Manager premium
LEDs Hack
Gentle Alarm
) Both my laptops can still see both of the APs in my house, and I have no neighbors to "step on my signal".
Any suggestions?
