Root BAMF 1.5 remix battery question.
Well rebooting does use more battery. I usually lose anywhere between 2-10% on a reboot.
Have you cleared battery states in recovery after you flashed rom???
I seem to be getting great battery life with this mod, until I reboot... Then my battery level drops 10-12% each time. Any suggestions?
If you are losing 10-12% of battery life with a re-boot, then you need to wipe the battery stats. Losing that kind of percentage on a re-boot is a classic sign that a batt stat wipe is needed.
There are a few ways to do this, the easiest would be to charge the phone up to 100%, then reboot into recovery. When in recovery go to Advanced>Wipe Battery Stats, then reboot.
The way to do this is to get a battery stats wiper from the Market, there a few of them so just look around for one that you like. The apps will give you instructions on how best to use them, and come with a few other bells and wistles.
I am using the BAMF 1.6 Debloat ROM and have the 2750 mAh battery. When I reboot, I get a battery hit as well, usually pretty significant. However, with this ROM currently the battery life is great! I have been on the phone for about 45 minutes and gotten about 40 emails and read/responded to them and still at 97%. I drove to this client's office about an hour ago and it was plugged into the cigarette lighter, but the above activity has been SINCE it was unplugged!
With the STOCK ROM. I'd be lucky to make it for 4-5 hours!
