lowlow5683
Is there a BareBones CM7 rom for MT i would love it
Great thanks this should work for MIUI aswell right? See i had a barebones rom on my intercept awhile back and i loved it cause i was ablle to basically build/personialze my own rom with all my own apps that i picked from different rom...Oh and Gman i love your take on cm7 keep up the good work
This should work for MIUI however I am not sure all the apps are the same. Just trial and error. As for the rom I am making baby steps at best. I have inserted wsimons code for hdmi but still troubleshooting the blue screen output, at least the HDMI is registering when you plug in the cable thanks to his work. The biggest problem is finding the time to work on it at as it takes a lot of troubleshooting and building and testing. After diving into this project and seeing the time it takes to work on a it I am in sheer ah with all the work the dev's have put into the Triumph! My hats go off to all of them!!!![]()
Couldnt i just use system app remover cause ADB is new to me and have actually no idea what it does or actually how to use it sorry fo rbeing a noob
couldn't you just remove the .apks from /system/app in the .zip?
now will that free up the rom space? it should logically right?
It could possibly free up some internal storage, depending on how many apps you remove and how big they are. Although I really don't think you will be able to free much more than maybe 50mb... If that.
