Root Baseband Casio C811
tiger1912
Can you help me extract the latest baseband of the C811? Thank you very much.
Give you the latest ROM: https://docs.google.com/file/d/0B8nckZgkTcbLb1VZNG51OTRhTEk/edit?pli=1
1) Download ROM G'Zone World Pro and extract it to /mnt/external_sd/clockworkmod/backup/ (External Storage)
2) Download CA-201L Rooting.zip and extract cwm_ca201l-signed.zip and root_ca201l-signed.zip to /sdcard/ (Internal Storage)
3) Download Initialization_410_tool - it's a stock Korean firmware and put it to /sdcard/ (Internal Storage)
3) Turn off your phone
4) Hold Tacticle Key + Volume up + Power button until you hear a short vibration.
5) You should load and see Android robot with opened stomack.
6) Press Tacticle Key and stock recovery should appear.
7) Choose apply update from external storage and flash cwm_ca-201l-signed.zip
8) then flash Initialization_410_tool.zip
9) reboot system now
10) No when booted to Korean firmware go to phone settings - Backup & restore -> Factory data reset. That should lead you to CWM recovery.
11) Now flash the CWM again: cwm_ca-201l-signed.zip and root_ca201l-signed.zip
12) Now reboot to system
13) Go to recovery again, choose "backup restore" -> "restore from external sdcard" -> And choose G'Zone World Pro
I moved this to the All Things Root sub forum where I think you will get a better response.:)
