Basic call answer question
TomD1951
Hello,
My old firmware allowed me to turn off an incoming call by turning the phone over.
With the Jellybean update I cannot find where to set this option. I figured you guys would know.
Thanks for any info.
Hello,
I can't find it either. I was sure I had seen it since the update, but can't find it now. Perhaps it is no longer available
I put a "ByMotion X" app on the phone, seems to work ok, its pretty fancy for what I wanted it for but it does the job.
Something else that's a bit sad is not being alerted in some way by an alarm when the battery has reached 100%, used to have it in Gingerbread but alas not on JB. :(
Mine doesn't make a noise when fully charged. I'm on the first JB update, whatever version that is.
It's also going a bit mental. I can restart it and it'll lose around 5-10 percent. Might be the battery getting dementia, I dunno.
I also have the first JB install, i dont use mine like you guys do (mostly calling), so i dont know what i am missing.
I bought this one unlocked, its one of the few "smartphones" that isn't the size of a dinner plate.
