I almost forgot... I also just unlocked my bootloader... dunno if that matters...?
funkylogik said:Lunatic's advice is sound...
Do I need a .nomedia file in each folder? Or just the parent folder?
Can I use Widgetsoid media scanner button instead of reboot?
Unlocking the bootloader should have wiped the phone of all previous user files and data. If you copied the ringtones from a backup, it's very possible that you neglected to backup the .nomedia file, since it's hidden by default.
Pun intended?
A lot of music players have a way to tell it where to look for audio files. And ways to exclude area. Check in the app settings
