wedgemoose
I've always wondered this and figured it was time to make sure. How do you tell what running? I know where you look. Under "manage applications" then "running"....
but when you click on the running program, what do you look for?
the only thing i see that either has "0" or a number is "Cache"
so is that it? if there is a number other than zero in Cache, it's running?
the reason i ask is because a certain app that i got out of an hour ago has 84.00kb in the Cache column....
Or if I'm wrong what do we look at specifically?
thanks in advance
thanks in advance
