Bathroom questions
Rgarner
Android Expert
There are some cracks in the wall where things join. How do we fix them? Also, how do we install a new showerhead? The old one is blasting all over the place.
The skirting boards("wall things") look rotten to me. Should really be replaced, but you could try Pollyfilla or similar caulking. Is that room damp. does it have mould, the black spots? Where I am, wall skirtings are usually ceramic rather than wood. As for shower heads, they usually just unscrew and screw on.
I'm with Mike... you can buy white caulking in a tube and fill the cracks in your baseboards. Replacing would be great but patching will suffice on the cheap. You should be able to simply unscrew your existing shower head and screw in a new one.
Yeah, try actually using the darn thing. The boards I guess are rotting wood, but as far as I'm aware no mold. There was a leak quite a while back over the weekend and didn't get fixed until the following Monday. That probably explains a lot of it...
those boards should come right out. you should be able to find replacements at home depot. but you will need some wood cutting equipment to cut them down to size. once removed you should see if there is more water damage or not and you will probably need to paint the boards as well.
the shower head should just unscrew off. you can try soaking it in some hardness remover or try soaking it some distilled vinegar for a few hours or overnight.
if you want to dyi check some youtube videos. they will help out tremendously....like this one:
Thanks for all the replies and yoy're right about the screw on/off thing. However, when I took off the old one and tried putting on the new, it didn't fit. How do I take care of this?
Fyi, the old one is silver or chrome and the new one is white. Tha last one is where it goes. They're not such great pictures but maybe you can tell.
Damn!
If I where you, I'd gut that whole shower enclosure and start with brand new everything!
The mold and leaks are just gross, and also a health hazard. Good luck with that nightmare.
Let's do Gofundme or maybe there could be a crew working on it, a sort of Amish bathroom raising. Meanwhile I went and got some caulk, which led me to realize that I have no caulk gun. It's that acrylic kind. The showerhead has yet to be replaced, but I guess it's ok to do without it for now. It's not really any blastier.
You can buy the caulk in squeeze tubes but it is an expensive option. Before you attempt to caulk the cracks and joints that have come apart from warpage, wash all of that woodworking with a diluted Clorox solution. It will at least kill the mold that is likely there.
