hello all,
firstly I apologise for my first post being another battery question but to be honest im totally lost in all the advice ive read on literally hundreds of "battery threads"
im hoping i'll get answers to "my" problem rather than trying to weed out from many others what i or the phone are doing wrong.
I bought the HD for the single reason of excellent pics & video capabilities
im completely fed up of the horrendous battery life.
ive had some advice and have a task bar type thing across my home screen where I can turn wifi, BT and brightness on/off.
my home screen has a non moving wallpaper image of one of my boys.
im not into twitter/facebook or any other social site, to my knowledge I dont have weather switched on and havent any email accounts set up on it to update to.
I have only a few apps, daft stuff like whoopee cushion, a fart horn thingy and a few angry birds that I havent touched in weeks.
I check ebay at work the odd time in a day for no more than prob a min or so (just to see if anything in my ebay is ending)
I use the phone for maybe 20-30 mins per day to make calls and send prob 20-40 texts per day
ive got into a routine of charging it overnight as I have NO faith in it lasting passed midday the next day if not.
I can go to work at 6.30 am taking it off charge and by easily 8am its dropped from solid to missing a bar of green charge (like a missing bar in the old style mobile phones)
im a bit of a technophone really so am totally unsure of what can be zapping it.
ive gone into the settings and the "what's my battery using" tells me this
display 55%
cell standby 17%
phone idle 15%
voice calls 9%
android 4%
I dont have a battery % indicator, its just a green line and atm shows a little over half way.
The phone says its been 2hrs 51mins from removing from charge, so its dropped nearly half way in 3hrs ???
and ive been at home all day with the kids off school, so I havent checked internet once, made prob 5 mins tops of calls and prob 5 texts to mates rubbing it in that im off n theyre not
I intend to try the advice about charging/turn on/turn off etc etc and see if that does anything. I did the recommended charge for ages when first bought so am completely stumped as to what is wrong
on a side note, Im wanting to use my home internet router when at home on my HTC but although it says it can see my sky router it refuses to connect. it tries for maybe 10-15 secs then just says "disconnected"
the icon nearly always says E as well, is this a poor Vodafone internet signal or a good one ?
any help would be great as although Im getting fantastic pics/vids of my boys I have zero confidence in taking it anywhere really, which is mad because I do know its capable of so much more.
display 55%
cell standby 17%
phone idle 15%
voice calls 9%
android 4%
