Battery app question.
peekapoo
I saw evo screen shot had stock battery icon shows % of power left.
I know few battery apps show that, but they are widgets, not changing stock battery icon.
Can anyone tell me which app is that?
Umm you mean the one that shows the battery percentage in the left side of the screen? One I know of is BatteryTime Lite
Thanks for your reply, but no.
I don't want to add anything on screen, just want to change stocked battery indicator to show percentages as well.
I use Battery Status Pro. It doesn't change the stock battery graphic but puts a new one in the top left corner with percentage.
