Battery/App question
Ilphay
Is there anyway to find out what apps drain the battery the most? I've noticed recently my battery has drain A LOT quicker and I'm wondering if it's due to an app. Yes I have my gps, wifi and mobile data turned off most of the time.
Any ideas?
Go to settings>about phone>battery use. Tells you everything that is using up your battery.
