miniprosadface
Hi guys, I have had my minipro since Sept. It's worked great up until the upgrade of Android system. Yesterday, it was charging and I removed it from the cable at about 75% charged. I was texting then plugged it into my laptop to charge it fully. I noticed it got really hot and was dead. So I removed it from that plug and put it into the wall for charging. An hour later....it was completely and utterly dead.
I went to the Carphone Warehouse to seek guidance on troubleshooting it.
We tried charging it with a different plug but no luck, then we swapped out the battery and it worked. Problem is, it was dead on charge so I turned it off and went home. I went to plug it in and nothing. I took the battery out and found that it says 'FOR SON ERI W580i'
I am hoping that this battery did not blowout the phone. The worst part being, I have to catch a plane tomorrow for Italy to work for the week and I was rushed to get this sorted today. I pray I have time to get it sorted before I go in the early afternoon.
