fireonhigh
does this work?power cycling? Battery calibration: for good battery life - xda-developers calibration is simply done by running it down completely until the phone shuts off by itself...
Then remove the battery, wait 10 seconds, insert again, repeat...
If the phone shuts off again in less than a few minutes you're done.
Now remove battery and hold power button for 1minute.then insert battery.dont switch on the phone. plug the charger and recharge the battery fully until the green light is on...
then remove battery,hold power button for few seconds,insert it and switch on the phone...
yes its done......
do this initially once in 3-4months when the phone is new.then ince a month after a year to gain maximum battery performance...
REMEMBER THIS WILL NOT DRAMATICALLY IMPROVE YOUR BATTERY LIFE....
BUT THIS WILL SAVES YOUR NEW ONE TO BE DEAD BEFORE AGE
DONT EXPECT MORE FOR ALREADY SWOLLEN OR DIED BATTERY...
yes its done......
