asleep or turned off? turning on the phone can use a few % of battery usually
But look at the part where the screen is off... theres a lil gap in the graph then when the screen comes back on, its dropped a good bit (faster than with screen on)...
That's a reboot mate
So if it takes so much power to boot, does it use a lot of power to shut down (when you run your battery dry, does the phone save a few percent so it can shut down properly?)
And does that mean that if your calibration is off a bit, the phone could shut itself down too soon, shortening battery life?
