Help Battery can not be charged.
Wise11
hi
my device sammsung s4 galaxy, my battery is damaged.please give me solution.when i connect my device to electricity no charging happening.
answer me
Check charging with a known-good charger and/or cable. This will eliminate faults with the supplied charger, and indicates either a failed battery or a hardware problem with the phone itself.
If your battery is damaged, you should replace it as possible... there are a lot of dangerous chemicals in there that are protected by some nice electronics...
You really don't want to mess with it, and if its mishaped in any way, get rid of it.
i think the problem form device mobile not charger, i used many chargers same problem for all chargers
are u sure?
If you know for a fact that there is something wrong with the battery, then the only solution is to replace it with a new one. Not sure what else you're looking for here-
I'm not sure what you mean, or what you want us to tell you. :\
If you think the battery is broken, your only fix is to buy a new one.
I didn't watch all the video, but he's talking about an S5, not an S4.
