Help Battery Charge Done
Hapdroid
Can anyone tell me how you turn off the vibrate feature that goes off when battery is finished charging? I use my phone as my clock which sits on nightstand, so of course it finishes charging very late and vibrates waking me up. Thanks!
I think that's one of those features that's not able to change. I know, it's an annoyance to me too.
I see OP had double thread.
Anyways, I don't know if you figured it out or not.
But here is some tip. If you disable the screen lock, It might still ring or vibrate.
If you just disable battery pop-up, It just lit up screen for 2 sec and goes out.
