My Samsung Fascinate vibrates when it is done charghing, it is on my bedside & wakes me up when this happens. Is there any way to turn this off? Thanks
Go into the Dialer and enter *#83786633 then press the Home key
Go back into the phone dialer and enter *#22745927
Now a box will come up asking for the SPC code. Enter 000000
Press the Hiddenmenu Enable radio button.
Now you can use these codes.
The dialing code string you have to use is *#<code>#
Full Bat Popup
*#3844228#
This allows you to disable the full battery pop-up.
I have tested this and it works successfully.
Just silence the phone before you go to bed. Simple, either swipe down the top bar and press silent or hold the power button and turn on silent mode there.
DONE,
That just brings my notifcation bar up??? Mine does not vibrate, so no big deal, but i'd like a 1 touch way to go from ringer to silent. What do you mean?
