With the Samsung Vibrant there is the USB cable and the charger that you plug the USB cable into (to charge it from the wall). I was wondering if charging the battery from a PC was any different the plugging the USB cable into the wall charger? I would like to just keep the USB cable plugged into my PC and charge it that way but I want to know if it will get the same charge as it would with the wall outlet..
