Help Battery charging issue
amedhat
when i put my cellphone on charge it may take about 10 hours to reach 80%
today i put it on charge for 7 hours and it reached only 18 %!
I have been having this problem since last week, i reset it and nothing has changed
Welcome amedhat!
Are you using the computer or the wall charger?
Are you using the OE cord or a different cord?
I would suggest a different cord or a different wall charger first:)
i am using a wall charger :)
All righty! Do you have access to another cord or wall charger you could try first?
The other thing to check is that the micro usb port is clean. Try some "air-in-a-can" to blow it out.
Also, just check the contacts on the battery and the contacts on the phone. Perhaps clean them off with a pencil eraser. :)
