Battery/Charging Issue.
marcjohnson
Has anyone had this happen to their Note?
When unplugging it from charging the phone switches from still charging to not even though its not plugged in?
I swapped batteries as I run two, when switching it on it shows the symbol of the battery not charged than charging that you get the very first time you switch the phone on when you buy it.
I then plug it into my pc and it tells me that the usb device has failed and does not recognise it so I can no longer add music to it.
Has anyone experienced this and is it a hardware or software problem? I can't upgrade until Jan so really need to get to the bottom of it.
Thanks in advance.
