Help Battery Charging Question
Barats
When I am charging my battery after the Froyo update, it slows WAY down when it hits 90%. I'll usually charge when it gets below 10%. And the time it takes to get from 10% to 90% is almost the same amount of time that it takes to get from 90 to 100. Anyone having that problem? I mean it will eventually get there but it used to never do that.
It just happens. I've seen posts on this before. Nothing particular causing it, and I wouldn't call it a problem. It doesn't effect anything. Just your battery charging the way it wants I suppose
