ithejdi Member May 24, 2010 #1 I was trying to find the code to get into the real battery info. #*#* ??? or *#*# ??? I did try to search but it does not understand #*#* due to the built in Boolean search.
T thenestor Android Expert May 24, 2010 #2 ithejdi said: I was trying to find the code to get into the real battery info. #*#* ??? or *#*# ??? I did try to search but it does not understand #*#* due to the built in Boolean search. Click to expand... I think you're looking for *#*#4636#*#* which gives you battery use, battery history, and battery info (without having to install Spare Parts).
