Help battery cover doesnt fit
gt33
Member
The left lower side of my battery cover doesn't fully snap into place, causing an annoying gap. It was never like this, but I took the cover off to remove the battery, and when I tried to put it back in, it wouldn't snap. I tried a different cover and it still didn't fit... I have no idea why it wont snap in all of a sudden. Anyone else have this? I'm on my fourth epic, If I have to go to #5 I might just say forget it and save my upgrade
Push it in harder. (the back that is)
The battery ive discovered that you have to get in in perfectly before it wants to get inside
