Accessories battery cover
randy_c
I want to paint the battery cover plate to match with the phone but before I do. I want to know if you know where I can get one?
Thanks
I wasn't able to find anywhere online that sells them... but in the case of most replacement or spare parts you could probably call Samsung's support (or your carrier) and order a new battery cover... (did this a while back with an LG I had)... worst case scenario people sell bust old phones on ebay all the time... It may not be new but you could probably pick up another captivate that doesn't work and use the battery cover off that for a couple bucks...
Good luck in the search man!
