Try to think back what changes you made, apps/widgets/syncing/roaming, etc right before noticing the battery life change.
The "usual suspects" in quick battery drain are Weather Bug, Facebook and Gmail syncing loops (trying to sync at the same time), media playing unnoticed in the background, wifi, Bluetooth, etc
I'd go into the application manager and check running services, also. Perhaps you'll see something unusual in there.
