Help Battery Discharge
ghamden
I noticed battery shows exact up time as awake time
maybe there is something staying active causing battery drain???
just got it ota as soon as it turned so it is a clean startup no issues so far except noticed the battery use as decribed
Check bluetooth WiFI 3 or 4g gps display and other battery killers and make sure they're off then go to manager and see what is using most battery. Maybe this helps? Olskool
