Root battery display question/font question
bcrtj457
i dont know where i saw it, but I've seen someone with their phone set up like this, instead of just the green battery icon at the top in the right hand corner, it actually displays the percent too. is this something i can just flash right to my phone? or is this not possible.
i also was wondering if anyone has heard anything about being able to change the entire font on your phone. i would love to be able to customize the font! i know i've asked before, can't hurt to check again!
thanks if anyone can answer either of these questions.
Yes and yes to both your questions.
Go here to change your stock theme to Manup's Evo theme, it's probably the most popular right now. You can even leave the theme and just install the font packs and whatnot:
[THEME] 8/11/2010 Manup456 The EVO Collection 2.2 UPDATED =) - xda-developers
Then this is the battery indicator with the percentage display that I am currently using:
http://forum.xda-developers.com/showthread.php?t=752658
There's also this one, which is the segmented circle with the percentage in the middle:
http://forum.xda-developers.com/attachment.php?attachmentid=373947&d=1281025587
Everything in those threads are flashable :).
i should also mention that i'm running fresh's newest rom 3.1.0.2
with the kernal 2.6.32.15-king-HAVS-OcUverik@Ubuntu#7
also using launcher pro plus.
Yes sir. Drop it in your SD card, flash in recovery and your font will be all set. It'll completely change throughout and look really good.
Yep it does, a bit of warning though as the circle battery indicator will overwrite your theme, so I'd suggest going with the one I'm using. Not to mention it just looks cleaner, too.
8/20/10 Smooth-REVOlution with Battery Percentage 1.0.1 based on Manup456's REVOlution 1.1r2 theme. This should be flashed on top of Manup's theme.
8/20/10 Smooth-REVOlution without Battery Percentage 1.0.1 based on Manup456's REVOlution 1.1r2 theme. This should be flashed on top of Manup's theme.
8/20/10 Smooth-REVOlution with Battery Percentage for CM6RC2 0.9.8 based on Manup456's REVOlution 1.1 theme. This should be flashed instead of Manup's theme. Read the changelog for full details on applying.
8/20/10 Smooth-REVOlution without Battery Percentage for CM6RC2 0.9.8 based on Manup456's REVOlution 1.1 theme. This should be flashed instead of Manup's theme. Read the changelog for full details on applying.
which of these four files would i download?
the page i was linked to has a few different options for what to download. which one is the one you are using? that won't change anything on my phone EXCEPT battery percent indicator right?
that's amazing. thank you for your help. it's nice to be pointed in the exact direction im trying to go!
Hmmmm...That is one question I was going to ask myself, haha. It seems the font looks very nice, but is indeed a bit small. I like the first fontpack more, but the second is more readable. It's just not as crisp or clean as the first.
at least the font is changed. i can live with this for awhile! again, thank you for all your help. both battery and font are changed :) thanks!!!!!
