i see the battery level is under 15%, i plug in charger, turn it off
i see the battery icon trying to calculate how much battery left
it shows half full
i turn on phone again, battery is at 50%
it shows half full
Check your battery stats in settings that should show you the correct level, you may want to try recalibrating the battery to see if that fixes the issue
