Vegaspilot
Hi all, just got the EVO today and it has a build date of 6/22/10 and is V003. Everything seems ok on it (there is a little bit of light leak, but not bad...I inspect a couple of them and they all had the lower screen level with the bezel while the top was recessed slightly) except for the battery door. It seems snug enough and doesn't pop off, but the right side (if you're looking at it, opposite the volume button) isn't flush. It's as though the two lock tabs on that side don't completely engage and you can manage to get a finger nail in there to pop it off. I know its a little OCD, but I don't like it. Anyone else have a door like that? I searched, but didn't see this exact issue. It will stay fairly flush on that side until you snap in the other side and then it lifts up. Should I try to get a new door or just exchange the whole unit? I know it's probably not a big deal, but to me it's annoying. Thanks.
So far I have replaced two battery door covers in my quest to find the perfect fitting one. And while it does fit MUCH MUCH better than my original battery door, it is still a tad off, maybe a millimeter or so. ONE DAY I SHALL FIND YOU, PERFECT BATTERY DOOR!
