JSchu22
With the battery door being so difficult to get off (it absolutely is), I tried using a nickel and it popped right open. Use this method at your own risk as I suppose you could scratch the metal body and/or mar the plastic door. Wouldn't hurt to put a thin piece of paper or plastic between the coin and door as well. A nickel probably works best since it has more if an edge to it than other coins.
