Help Battery drain, please help!
mad8196
Guys, I own a Sony Xperia S. I've attached pictures here, which are pretty self explanatory. Please help! :-(
28% after 13 hours is about 16 hours, or 2 work days on a charge. As the screen says, reduce your screen brightness and reduce the timeout and you'll get more. But 2 days on a charge isn't terrible.
Actually, it was on standby for around 7 hours. That's the problem. The screen stats show its been on for 3-4 hours, that's the actual time I've used the phone. Cpu has been awake for 6-7 hours for some unknown reason. :-/ ans brightness is down to 25% always.
Thank you for the replies! I installed wakelock detector and noticed backup is sucking my battery. What do I do? I have it disabled, yet it drains my battery :-S
EDIT : Okay I just noticed back up was enabled. I have no idea how it was enabled. I disabled it now, I'll see how it goes and let you guys now! Thanks again :-)
And about the media server, I don't have any corrupted image files.. Why would it still run in the background? :|
I guess media server always runs in the background to keep things updated but I havent noticed any battery drain from it
Try disabling apps you don't use... Go to settings and make sure nothing is set to synch (if you want to do it, do it manually).
Install a task killer and set it to terminate apps you don't use at regular intervals automatically.
Finally let the battery run out and then. charge it all the way to 100% without turning it on. Download a battery recalibrating app from play store.
