Help Battery drain spikes
So I've had my captivate glide for about one year now and I've loved it. Just recently the battery has been acting weird and draining really fast. Now it goes from 70% to 0% randomly. If I don't plug it into the charger it takes about 10 minutes for it to reboot and then it usually has around 50-60% charge on the battery. Should I replace my battery or get a new phone or something?
Attached is a screenshot of the battery usage from settings
ImageShack
sounds like the battery is starting to go.
depends on how often you put it on charge and for how long..
I would suggest you try a new battery and see how that works.
