Help Battery Drain
jamala00
I have experienced a couple times something just draining my battery very fast. I look at the battery stats and nothing stands out. If I reboot the phone it seems to stop it. I can't figure out what does it.
On another note, I got rid of my creaky case. I ordered a new back cover and the creaking is gone. Leads me to believe the hot\cold temp changes cause the back cover to lose its shape\form.
Thanks for the tip on the creaky back cover. Mine has just started creaking. I can live with it -- but it's noticeable.
A couple of things I've noticed will drain my battery quickly: leaving the traffic layer of Maps enabled and if I'm in an area with weak cellular signal for an extended period.
