Why is my battery drained so fast? Look at the attached screenshot. The screen isn't even on.
Hi norwegian82 ...Why is my battery drained so fast? Look at the attached screenshot. The screen isn't even on.
Hi norwegian82 ...
Welcome to Android Forums.
It seems that you may have a rogue or incompatible installed app. Perform a full reset of the device. Hopefully this should fix the problem.
Good luck.![]()
A simple reboot pretty much won't solve a problem like that.Seriously? You'd recommend that before just doing a simple reboot? I've had this type of issue a few times (a lot more on my old Droid) and I've never had to do a full reset.
random question but does your phone have a habit of losing power completly at a random % and then the only thing that will get it going again is to plug in the charger?
otherwise, what exactly are you doing on the phone?
So as you can see I lost 35% of my battery without really doing anything.
After trying a reboot.
I guess a reset should be the next step?
OP, I notice the Clean Master icon in your notification bar. If you are using the task killer (or "1 Tap Boost") feature of that app, it could very well be the cause of your issue. Task killers are totally unnecessary in recent versions of Android, and cause drain by constantly killing off system processes that automatically restart themselves.
