paligap
Ok - so I took the plunge today and went to the 2.1 leak...installed perfectly thanks to Matlock's guide - LOVE 2.1 - it's awesome!!!!
Just have a ONE MAJOR PROB (and a minor one) - my battery is literally draining before my eyes!
It will be at 80% and I will load the weather and maybe respond to a text and it will drop to 79%.
Then if I just flip screen to screen - another 1% gone in less than 15 secs!!
I have searched through the forums but haven't seen if there is a 'fix"
I have build 2.26.60534 CL140744 - that's the latest, correct?
My Minor issue is signal strength - I use to have 3-4 bars constant and now am lucky if I get 2 - again saw others had the same prob but didn't know if there was a fix besides the *228/2 -
I have powered off - taken battery out - that gave it about 10% more juice but still declines rapidly as before...
REALLY NEED SOME HELP ON THIS TO PROVE TO MY WIFE I AM NOT A TOTAL IDIOT (please keep those comments to minimum - at least til my problem is fixed) AS "SHE WARNED ME"
2.1 rocks you just have to find out whats killing your batt
I know - lame but it's cool -
