ironass
Extreme Android User
Huh? i don't have a huge battery drain as i said earlier, what i am saying is its worse under Lollipop than it was under Kitkat, especially when the screen is used properly. My screentime is a good 30mins-1 hour less than what it was using kitkat.
That's odd as independent tests and my own experience, show Lollipop to be more battery friendly as I stated in the Introduction of
S5 Lollipop Update Problems - Dummies Guide. This does not mean however, that you have not encountered some issues.
If i had a corrupt update wouldnt i be seeing issues all over the place?
Not necessarily. As you know, it only takes one, "i", not be dotted or one, "t", not be crossed and as with any software, it can have a minute knock-on effect.
Lollipop 5.0 is crap, lets face it. Hopefully 5.0.2 will cure some of these issues, well i know it will.
I will beg to differ, as my own experience has been very good on Lollipop. In fact, stock Samsung Lollipop was launched worldwide with 96 releases over 2 months and there was hardly a comment on these forums about it, see here, prior to the release of the Verizon version of Lollipop which, I will concede, is less than satisfactory it would seem as there are now a multitude of posts regarding it.
